R
- 0
- 1957
My 1957 T-Bird has what I think is a fuel starvation problem. It happens under a load, particularly a very specific freeway on-ramp, which has a sharp right turn going up an incline. It's happened at other times, the commonality being a right sweeper turn at freeway speed, while accelerating under load. At that point the engine starts to die. Fortunately it doesn't shut down altogether, I think it's the Fordomatic that keeps the engine turning while in gear. It feels like typical fuel starvation, not herky -- jerky as would often be the case with some ignition issues. So when the engine starts dying, I keep the accelerator pedal steady, and 5-10 seconds later the engine comes back to life.
The ambient temp doesn't seem to make any difference, so I don't think it's vapor-lock. I installed a new gas tank a few years ago and it seems to have started around that time. I've also installed a new fuel pump (stock mechanical) and a new fuel filter (factory glass-bowl type).
This engine dying under those conditions seems less prone to happen when the gas tank is filled to the brim. The new tank I bought was good quality / good reviews, however I'm thinking it doesn't have baffling in bottom of tank. I'm not certain, but I'm guessing the factory tank had baffling. Has anyone else had this issue?
