R
RD SHARP
- Oct 31, 2022
- 1957
How do you remove a power widow motor from a 57 Thunderbird?
Please
sign in or
join the Thunderbird
If you forgot your password
click here
There is a pretty detailed description in the shop manual. Too much to go into on here. Not too difficult but time consuming.How do you remove a power widow motor from a 57 Thunderbird?
Thanks, but my 1957 Ford car and Thunderbird Shop manual does not describe what must be done to get the motor out. It does give a vague description of how to remove the glass and actuator, if all that is necessary.There is a pretty detailed description in the shop manual. Too much to go into on here. Not too difficult but time consuming.
The motor and lift mechanism come out in one piece. I pulled mine when I replaced a cracked window. The hardest thing was getting to the spring 'C' clips that hold the rollers on the window frame. Don't try to force them off, the originals were pressed steel and will deform, I ordered new ones which are machined and much more solid. The other was replacing the broken helper spring. That thing is powerful. While you are at it clean out the gear box and re-pack with white lithium grease. My window zips up and down now.Thanks, but my 1957 Ford car and Thunderbird Shop manual does not describe what must be done to get the motor out. It does give a vague description of how to remove the glass and actuator, if all that is necessary.
I do it by feel with a wrench and once I get the nut loose, I then take my fingers and spin it off by hand.Thanks, Did you get to the bottom nut without making the access hole bigger? I'm thinking that I may have to do that. I would rather not but I would rather do that than remove the window and try to readjust it after putting back.
Never heard of issues with white Lithium and I disagree with that is what they used at the factory. Black is all they had at the time, but good grease is the solution which ever you choose. refurbishing the whole works while you have the chance is the way to go. You won't regret it.I do it by feel with a wrench and once I get the nut loose, I then take my fingers and spin it off by hand.
I also don't want to upset the rest of the user here and YES I agree that removing everything and lubricating it, replacing the window runs, front and rear, taking the mechanism out and lubricating it, also taking out the door latches, lubricating them, etc, etc is a good idea, but his question was about removing the motor. YES it can be removed without taking out the entire window mechanism.
ALSO, you may want to rethink white lithium grease. If you notice, the factory used white lithium and it has likely hardened solid and is not easy to remove. I use Mobil 1 synthetic grease, it comes in a 1 pound tub and is red in color. I quit using white lithium.
White lithium was patented in 1950. It was sold as "Brake Grease" by several commercial lubricant manufacturers and was used to lubricate the wear pads where the sides of the brake shoes come in contact with the backing plate. Interesting that you say you have never heard of white lithium hardening, see "1956 Window mechanism lubrication" in this forum that was posted today.Never heard of issues with white Lithium and I disagree with that is what they used at the factory. Black is all they had at the time, but good grease is the solution which ever you choose. refurbishing the whole works while you have the chance is the way to go. You won't regret it.
I agree on not using lithium. I have seen several posts that indicate that it hardens up after time.I do it by feel with a wrench and once I get the nut loose, I then take my fingers and spin it off by hand.
I inherited my dads 55 Tbird and there is no manual. Star wheel on the driver door no longer latches. It just spins. As this is all new to me could someone give quick instructions on how to remove the interior access panel so I can get a look at it? Thanks!You can remove the motor without removing the mechanism. Remove the access panel you can see the motor at the bottom. There are two nuts that hold the motor to the mechanism. One is not easy to get to, but once you get them loosened a few threads, you should be able to get them of by hand Once the two nuts are removed, you need to separate the motor shaft from the drive coupling. It may be stuck but it will separate with a little tug. Once it is lose carefully remove the motor and disconnect the 4 wires by separating them at the bullet connectors. if you have the original or original style motor, just match up the colors to reconnect the motor. Be careful of the small cupped washers that go on both sides of the mounting flange, You can get the rubber grommets but the special washers are not available
Are to talking about the cardboard door card? it's pretty easy. the hardest part is removing the door handle and window crank if applicable. There is a spring 'C' clip holding them onto the shaft. They can be pushed off from the handle side with a special tool ( inexpensive ) or a small straight blade screwdriver. Keep an eye out for that clip if it pops all the way off, You don't need to remove it that far, just enough to release the handle.Removing the inside panel is the issue I have. I don’t know how to remove it and don’t want to damage anything. Does anyone have info on how to remove the interior door panel to access inside the door?
