1957 power brake booster leak | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter curtkane
C
1
I am loosing a little brake fluid. Check all over and see no visible leaks. Suspect it is at the power booster. Being sucked into the engine and burned. Would a rebuild kit solve the issue.
A master cylinder can be rebuilt. It’s usually necessary to hone the cylinder before installing new components. If you already own a brake cylinder hone. Or know where to borrow one. It’s cheaper to rebuild.
The booster doesn't contain any fluid, it there's any in it then it came from the master cylinder.
The booster is a separate unit mounted separately on the inner fender well; it is not integral with the master cylinder as in later models. The brake fluid is routed to the booster via a regular brake line where the "boost" is applied.
Is there any evidence of fluid in proximity to the booster? Have you checked the wheel cylinders?
Yes, check wheell cylinders brack lines and master cylinder. Disconnecter vacuum line going to booster and plugged it. Don't see fluid lose and brakes just a lttle harder.
Its not booster in the "normal" sense, it is a Hydra-vac system like used on trucks of the 50's and 60's. It is mounted remotely from the firewall mounted brake cylinder. disconnecting the vacuum hose does not stop the leak as the hydraulic cylinder in the booster is still leaking.
