1957 Measurement - Ground to top of Seat | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter lbaker1947
lbaker1947
lbaker1947
Need help - My wife has problems getting into the 76 Corvette I sold. Now I have my sights set on a 57 T-bird. Can't find one local to measure. Need your help, could someone send me the measurement of the ground to the top of the seat. Does anyone have sketches or tables with this type of info?
Roughly 19 inches. Things to keep in mind with that number, it's from a straight edge laid across the seat and sticking out the door opening, then measured from the straightedge to the ground. The seat has brand new foam and probably sits higher than many cars with several year old foam might sit. It's also a measurement from the tip of the bolsters, not the center of the seat where your butt sits. The butt point would would make the measurement perhaps an inch less, 18". Also my springs are a little saggy. It would sit about 2" higher with new springs, maybe more, 21"+.
It also has much to do with the way you enter the car. As a “full figured” male (5’11” 205lbs) the trick is to enter head first, lay your hands on the seat, then twist towards the left as you draw 1 leg in. While this could be well known by many T-bird folks, it took me a few months to realize the ease of entry this provides. My 6’3” son tried the “ conventional way….” foot first. It was comical
Mine also has the 15” diameter steering wheel which makes a nice difference.
Thank you, Jim, understand lots of variables, just needed a point of comparison.
The difference between the the Tbird and the corvette is with the Tbird you don’t have to drop down into the seat.
but the head clearance is tight even for an average person
