1957 Holley Model 4000 Carburator Adjustment | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Mathys
Mathys
2
Car is a 57 T-Bird with the E Code Engine
Have a problem with the two Holley Model 4000 Carburator with Integral Choke (Tee Pot Carburator) Both have a new Overhaul Kit from Daytona Parts Co. installed. The Problem I'm facing is: Idle Speed is oscillating (pumping) within about 1 – 2 sec. period. Has anybody an idea where to start playing around adjusting things?
Experts on vintage Holley Carbs are not easy to found in Switzerland! Many thanks for valid hints. Regards Rene
First ensure you don't have any vacuum leaks.
You can try pulling one or two spark plugs and if clear gray white, the nixture is lean, due air leaks, suctioning air from a bad gasket, or your intake manifold leaking or yiur carb loose or one adjusting needle with the micro Oring missing or torn?
IMG_3562.jpegHernando many thanks for your fast and valuable reply. I decided to replace all Rubber Vacuum Hoses. As I have to organise them first it will take some days before I can give you feedback. Regards René
