SoloBird
- 8
- 1957
Has anyone here replaced all the fuel and vacuum lines with stainless steel braided lines and fittings?
If so, please share some pics to see how it looks and share the sizes and info you used.
I am trying to figure out all the fitting and hose sizes. I cannot find the name of the brass elbow fitting that goes from the back of the intake manifold to the fuel pump vac line. It seems like it is this fitting part. I don't have power brakes right now, but I guess the vacuum line from that would go to this fitting as well.
I am also putting in a new distributor, but my original one was a hard-line steel tube that screwed into the vacuum advance that went to the carb. The new distributor has its vacuum advance port for a flex vac hose style. What fitting and size do I get to put a flex hose on to the carb to go from this new distributor?
