J
John R. Dulin
- 11
- 1957
I have a 1957 T-Bird that I can't start. Recently had a new ignition switch installed as you could turn the switch to on and nothing would happen - and it still had the problem. Then I had a new neutral safety switch installed. The mechanic said that I had a bad battery when I went to pick up the Bird. I drove to the parts store, turned it off and again it would not start. We tried jumping it off with a battery jumper and nothing. The store manager then pulled his truck around to try and start it. Again nothing and this time smoke began to come out under the dash. The next day they installed a new battery and again nothing. The volt meter responds when the ignition switch is turned on but the starter does not engage.
