1957 electric window circuit images | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter twstnshout
twstnshout
twstnshout
4
Can someone post an image of the wiring through the 30 amp circuit breaker forward. Which wire goes on bat side and which on aux side?I have a 15 amp circuit breaker mounted on the inside the removable door panels but seems like it should be mounted in the kick panel area according to assembly manual diagrams and where the black wire on harness is located. I didn’t have the opportunity to see my project completely together before tear down as it was partially disassembled in the 70s and left, so the power systems wiring is confusing me.
Pages 107 and 108 from the Electrical Equipment Installation Manual should have all of your answers.
Mine's a '56, but they're likely quite similar. I found this resource invaluable when I rewired mine (dash forward). I hope it helps!20230302_103417.jpg
Depending on date of manufacture the 15 amp circuit breakers could be on the door panels, the 56 Ford T-Bird had them at that location. It could also be possible that someone installed new wiring but for a 1956. The 30 amp fuse is item FDR-14526-A1 or A2 Assy.
You are correct, the 1956 Thunderbird had the circuit breakers in the door panels. Since the post was about a 1957 Thunderbird, I attached pages 107 and 108 from Electrical Equipment Installation Manual. Here is page 63 from Electrical Equipment Installation Manual which shows the circuit breaker locations for the 1956 Thunderbird.
On a 1955 Thunderbird, the 40 amp circuit breaker was mounted on the firewall next to the hood latch and the and the 20 amp circuit breaker was mounted under the dash above the ledge. If the vehicle had power seats there were two 20 amp circuit breakers mounted under the dash above the ledge.
