1957-292 Y block rear crankshaft seal | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Hernando Muñoz
Hernando Muñoz
Hernando Muñoz
23
Hello friends
I have a Ranch Wagon with 292 Y block on which I need to replace the real crankshaft oil seal. I have removed the oil pan (tough job), removed the bottom seal aluminum holder, removed the last crankshaft support (and will loosen the other ones) to ease the job. Nevertheless, I don't see quite clear how to pull out the upper rope seal. Any ideas? I have seen videos, but they show when the seal is already coming out, not how to actually grab it when its extreme is totally flat.
Thanks for your advice.
Hernando Munoz
Costa Rica
I bought a tool, one end was Chinese fingers the other is like a very small corkscrew, very thin screws into the rope to pull it out.
I have used a small punch or medium sized flat screwdriver and carefully tap one end of the seal to get it started coming out. You have to be careful to not damage the crankshaft.
Mny thanks. I considered doing as you say, but my concern is the possibility of damaging the original rope seal (which is most likely worn, anyway) and not been able to remove it. So, I am tempted to just leave the upper rope (original) seal and just replace the bottom part with the new type of seal (made out of hard silicon) and meet the old and the new seal with some grey RTV, hoping to marry old and new seals.... hopefully it will work.
If it definitely does not work, then I will have to repeat the job and get the upper seal removed, like it or not. I am waiting now for the spare parts to get to my country and when done, I will get back to you with the results.
You may even be able to make a punch out of wood. No possibility of damaging anything.
It's like plugging half of a hole. After all your work, the last thing you want is to have to do it again. Replace the top and bottom of the rope seal and only after soaking it in oil for at least 24 hours. Good luck, I'm going to have to do the same thing on my 57 T-bird. Tese Y-blocks are notorious for rear main seals leaking.
This topic has been run around the barn numerous times, in my opinion the only replacement seal to use is the kit that Prestige Thunderbird offers. It is a slightly different design silicone seal with an entirely different design lower retainer block that they designed.
Comes with very comprehensive instructions, not cheap but bottom line is IT WORKS.
And yes it can be done on a creeper with the engine in the car.
Good Day
Roger
Actually the 312 which uses a different seal design is known for leaking. 292s and smaller use a different design.
