woodeye
- 13
- 1956
My temp gauge is pegged at hot with ignition off or on, but the wire isn't connected right now because I've got a mechanical gauge hooked up.
When i ground the wire from the old sending unit it goes all the way to cold.
I got a new sending unit from my local parts place and when we bench tested it it went all the way to cold.
when we tried it in water that we gradually heated it only stayed at cold.
When we disconnected the ground wire from the sending unit the gauge went all the way to hot.
The gauge does move to hot with key on if the wire is un-grounded.
Does this gauge need a unique sending unit, because the one from CASCO was $85, and the one locally was only $33.
The parts house said this is supposed to work with an OE gauge, which is what I think I have.
Thanks Jeff
Thanks Jeff
