- Aug 10, 2015
- 1965
I've owned my 56 for about 5 years now and have always had a very hard brake pedal. The car has been converted to disk front brakes and the booster is connected to the front. I checked the pressure at the caliper and it is 900 to 1000 psi regardless is the engine is on or not so the booster does not appear to be working. I checked the vacuum and it is 20 in. I replaced the booster about a year ago with no improvement. I also replaced the vacuum check valve. Any ideas? I wonder if there was an error when it was installed. The hoses to the front brakes are new and the booster is connected to the smaller of the 2 sections of the master cylinder. Road test shows my back brakes doing the stopping. The disks look very smooth and shiny so I am going to have them turned and new pads. What I cannot explain is why there is no boost. I bleed the system including the booster. When I press on the brake pedal, there is no sound from the booster. Ideas?
