L
lichau
- 1
- 1956
I decided to replace the instrument panel lights with LEDs. Worked fine, brighter and whiter. However, dimming doesn't work, at least with the LEDs I used. The light switch rheostat expects to be driving about ten incandescent bulbs at about 3W each--full brightness. The LED's consume a lot less than that. I found my LEDs dimmed to zero at about 8V. With the stock set up, full dim on the rheostat driving the panel with LED's is about 10.5V-- at which level the LED's don't appear any dimmer.
Being a long-time design engineer--electronics--I am adept at coming up with complicated solutions to simple problems. Visions of apps on my phone to dim the panel, and various other things were dancing in my head. Then I got talked off the ledge.
I found that a 25ohm resistor to ground on the instrument panel light string (red/blue, I think) simulates the incandescent load nicely. The panel lights extinguish about five to ten degrees before you get to the full clockwise.
The resistor is going to dissipate about 3-4W. Power resistor wattage is usually at a pretty high temperature. I put together a 23 ohm resistor out of four ten watt resistors I had in my junk box and the temp is OK. Bolted it to the dash cross brace.
You could put in a 10-20 watt incandescent light--if you could find one and didn't mind having your feet lit.
I am confident someone will have a more elegant solution. But, mine works. Off to the next issue.
