D
		DaveRo
- 0
- 1956
I have a 1956 Tbird with 292 cuin engine with 3 speed standard. On the flat part of the driveway, it idles at about 7-800rpm. When I roll down the sloped driveway, backwards, the rpm increases to about 2000. This is in neutral, no clutch. The engine doesn't have the original carb. It does have a new original fuel/windshield washer mechanical pump. The only vacuum lines are to the distributor advance and the windshield wipers. The wipers operate fine. There are no vacuum leaks. When I drive the car back to the flat area, the idle returns to 7-800. The only thing I can think of is the float bowl in the carb. But that shouldn't change with the angle of the car. Any suggestions?
