1955 Sea Foam motor treatment | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter mplamothe440
Anyone use Sea Foam motor treatment? If so, what were the results? Also any unexpected issues?
I use Sea Foam in my T-Bird and my boat every time I fill up. I have never had any adverse reactions. Both vehicles continue to run great. Don’t know about it being outdated….
Like they say, you learn something new everyday! Royal Purple is better for maintenance.
Sea Foam is a petroleum-based blend (pale oil, naphtha, and isopropyl alcohol) rather than a pure detergent.
Royal Purple: Is a detergent-based additive that
Contains high concentrations of Polyether Amine (PEA), which survives high combustion temperatures to scrub away carbon.
On a side note, Seafoam is preferred for engines that are gummed up or have been sitting for a while vs maintenance.
Full details from Gemini-
https://share.google/aimode/OefUbGRUoiBX5SCLn
I asked GROK AI to review things looking at both "reviews" and at the MSDS info. Below is what it came up with. For the PEA ones, they work best under "city" driving where you get cycles of warm up and cool down. It gets into the deposits and works on them while the car is not running. If you put it in just before driving cross country you don't get nearly as much benefit because there is no "sit" time for it to work before you have burned thru all the treated fuel.
GROK: After reviewing available data on popular fuel additives, Chevron Techron Concentrate Plus stands out as the top performer for cleaning fuel injectors, intake valves, and combustion chambers. It uses PEA, a highly effective detergent, and has strong backing from independent tests and real-world user results. Red Line SI-1 follows closely with one of the highest PEA concentrations among additives. Royal Purple Max-Clean also shows good carbon removal in soak tests and earns solid user feedback for smoother engine performance. Seafoam is a versatile option, excelling at moisture control and general cleaning, though it's more solvent-based than a heavy PEA formula.
Royal Purple Max Clean also has a fuel stabilizer, which is not included in the Chevron product. Royal Purple is a great company across the board. I use the synthetic rear differential gear oil in my Mustang. Both are detergents and a better option than petroleum-based Seafoam for routine maintenance.
Also worth nothing, they both help clean the carburator as well.
I just asked Grok too and it suggested to alternate between Royal Purple and Chevron which is a great idea!
Years ago I was a rep for BG Products. Their 44K gas additive was considered the gold standard for cleaning the upper engine. It was a PEA based product. It's a carbon dissolver, basically. They still sell it. I have no experience with the Royal Purple product. Sounds like a good one.
I have not looked into other current BG chemicals but they used to have several options based on service interval. There was an inexpensive one for use at every fill-up, another one designed for 5K intervals (it was an early version of 44K but then 44K was introduced), designed for 10K-12K intervals. 44K was too expensive to use all the time.
