G
Gpaws55Bird
- 0
- 1955
hello all, new member here. I’m getting my grandpas 55 bird running for him again. i have a decent background with carbs and classic cars, but never this old.
i’m in the process of rebuilding the teapot and i want to make sure i do it right. there’s 3 questions i have so far. i’ll try to attach pictures. the carb is a list 1071-1
1. my instructions say some holley 4000s have a discharge nozzle assembly. and they don’t have idle tubes. i think my version is that kind.
is there anything missing from this section? i believe it’s all there.
2. the gaskets between the main body and the float body are confusing. i didn’t get new ones. but i got a long piece of rubber and some thin pieces of metal. are those to seal the carb?
are there gaskets that i’m missing?
3. my accelerator pump is the reason this is getting rebuild. it was leaking a lot of fluid from the area that goes towards the throttle linkage.
so the first picture here. do i just pull the old rubber off and push the new blue piece on? or is there a different way to do it?
for the second picture. i don’t have a new small curved piece of wire that holds the ball down so i’m skeptical to take it out. i do have a new check ball though. should i replace it?
thanks in advance. i might have more questions.
