1955 Air Conditioning, correct refrigerant? | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Texas TBird
T
Texas TBird
4
My 1955 Tbird AC died over the winter. I want to add coolant to see if that's the problem. My SD507 Sanden compressor calls for R12. I found R12 or equilivent on Ebay, but want to make sure it's the right stuff. There's a blue cover on my compressor and I was wondering if that's a sign that the unit has been updated to R134. Any advice or ideas of how to proceed? Is my AC original or an aftermarket?
Title "1955 Air Conditioning" has been revised to reflect exactly what your post is about.
Per Google:
The Sanden SD507 (also known as SD5H11) is a popular, compact 5-cylinder aftermarket A/C compressor, often used in hot rods, custom cars, and heavy-duty equipment. It features modern rotary internals for reduced noise/vibration, supports R-12 or R-134a refrigerants, and generally comes with a 2-groove V-belt clutch. [1, 2, 3]
Key Features and Specifications:
• Design: Ultra-compact, lightweight, often with "ear-type" mounting on all four corners for versatile installation.
• Performance: 108CC ($6.59 \text{ CID}$) displacement, suitable for various aftermarket systems.
• Clutch: 2-groove V-belt pulley (typically $125 \text{ mm}$ or $132 \text{ mm}$).
• Port Type: Vertical top O-ring ports.
• Voltage: Commonly 12V (24V versions are also available).
• Oil Type: Usually requires PAG 100.
• Popularity: A common upgrade or replacement due to its smaller size compared to the Sanden SD508, making it ideal for tight engine compartments. [1, 2, 3, 4, 5, 6]
Compatibility:
• Refrigerant: Compatible with both R-12 and R-134a.
• Application: Frequently used in vintage air conditioning kits, tractors, excavators, and hot rods.
• Interchangeable Models: SD507 / SD5H11. [2, 3]
It is highly recommended to verify the specific mounting style (ear type), port configuration, and clutch pulley groove count against your previous unit to ensure proper fitment. [6]
AI can make mistakes, so double-check responses
[1] https://www.oerparts.com/product/ac5104n.html
[2] https://www.classicindustries.com/product/ac5104p.html
[3] https://www.amazon.com/sanden-sd507/s?k=sanden+sd507&tag=thunderbirdforum-20
[4] https://m.intl2008.com/products/a-c-compressor-sanden-sd507-9173-universal.htm
[5] https://www.vividracing.com/four-se...507-compressor-wclutch-58567-p-154302828.html
[6] https://www.ebay.com/itm/1873666532...pid=5338236430&customid=&toolid=10001&mkevt=1
The fact that is has the blue and black caps is almost certainly indicating its using 134a. The unit you have inside looks like the "modern" ones that have been used for a while. While that system/conversion, may have been done a while ago it was probably done after R12 was phased out which was in the early 90's, which, hard to believe, was about 35 years ago!!! It looks pretty much like my system, which I put on 3 years ago. When evacuated/empty they only take about 1 can of 134a.
As to whether its original or aftermarket.... They never had any AC option when these cars were new. They did add it aftermarket back in the day but way back then the compressors were the large square "York" style and many of the under dash units were large and ugly looking until Mark IV and similar style units hit the market in the 60's. They looked very similar to what you have.
I have installed air conditioning in my 1955 Thunderbird. I purchased the evaporator portion from vintage Air for about $500 is it match the interior of the 55 Thunderbirds. I purchased the rest of the components locally. The compressor came with oil in it for r134 and I wanted to switch it to r12 as I have about 130 lb of r12 sitting here in the shop and it works so much better. I purchase the solvent to flush out the oil in the compressor as it is not compatible with r12. I installed the correct oil for r12. All of the other components are compatible and do not need to be altered. Vacuumed the system and charged the system with r12 and I now drive around in Sacramento with frosted kneecaps. The compressor in the high and low pressure ports work just fine with our 12. I installed a vintage r12 metal sticker that would come on a older car so the people will know which refrigerant to replace with. Good luck and stay cool.
