- Jun 23, 2021
- 2004
When opening the top, it stalls after 1st fold. if I give it a push it will open the rest of the way. Motor still going/straining. Also. closes without a problem.
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Hi, where is the pump located and how did you fill pump? Thanks and happy motoringMore than likely low on fluid in pump. Mine did same and filled pump with fluid, now works like new
I had the same problem and used a little silicone spray and it works much better. I sprayed the joints to give it a little lubricationWhen opening the top, it stalls after 1st fold. if I give it a push it will open the rest of the way. Motor still going/straining. Also. closes without a problem.
Hi would you be able to clarify where I can find all these moving parts for my top?Go in and lightly oil all the moving hinges and pins, it helps. There is a spring that assists both of the folding arms, I am
sure that spring after all these years has lost some of it assist, which is causing some of the strain.
All the hinges and pins that need oiling are on the front convertible top section closest to the windshield, and the middle section, just lightly oilHi would you be able to clarify where I can find all these moving parts for my top?
Replaced FEM and checked all fuses and relays across the entire car. Also lubricated the tops moving parts and blew some air into the crevices but to no avail.All the hinges and pins that need oiling are on the front convertible top section closest to the windshield, and the middle section, just lightly oil
any hinges and arms that move or pivot. Since you are only applying one drop of oil, oiling the wrong part will not cause any harm.
