T
Thunderbird 2003
- May 20, 2022
- 2003
Smell burning oil when Hot. Don't see any leaks.
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I don't know if you've resolved this issue, but that smell could be oil lying in the area where the ignition coils reside. It's out of sight, and usually is the culprit that causes the coils to fail.Smell burning oil when Hot. Don't see any leaks.
Since you have an oil burning smell with no visible leaks under the car or any seepage on the exhaust manifolds, I would definitely remove the ignition coils and inspect for oil in the spark plug wells.Greetings,
I just picked up a 2003 with 63K miles on it. It's in good shape.
There are no visible leaks under the car but there is a smell as if there is some seepage onto the exhaust manifold(s).
Could the plastic valve covers be suspect?
I've read the spark plug coils can be a problem on these. I do not see them mounted anywhere.
Would the coils be under the inspection cover that are on the valve covers.
That's it for now, Thank in advance for all replies.
