- Feb 22, 2019
- 1966
Hi All,
My 1966 63D 428 town hardtop's Emergency Flashers are not working and never have since I've owned it. That's just over 19 years.
Sequential turn signals and brake lights work just fine, although a little noisy ;O)
I have a new two pin flasher unit and I have two new relays (the ones located in the trunk) on the way.
The two relays in the trunk were burnt out. So I assume that water got into them through the old drain hoses before I replaced the hoses many years ago.
I've checked the overhead console Emergency Warning Flasher Switch/Button and there is power to it and the light (although the light doesn't light up, yet).
My only concern is that when placing a multimeter on either of the connectors that feed the two pin flasher and to ground, both connectors are live 12v. I would have expected that the 383/386 connector ( that goes to X on the flasher) would be live and the 385 connector ( that goes to L on the flasher) would go to ground or be dead until the Emergency Warning Flasher Switch is engaged.
Can anyone help me understand why both these connectors are live please? Even without the two relays connected the flasher connectors are live.
Many thanks in advance.
