- Apr 17, 2019
- 1964
Hello All,
My mother is very sick and I am not able to work on the bird very much right now plug - state transfer inspection firstly so I can get it in my name.
However, I can design things and think of projects. As most of you know I have had some weird/strange/hacked up electrical issues with my 64. The fuse box is no exception. I have connectors in it that are rusty on the back and so on. I can/have cleaned it up, but I want the cleanest power possible. Not to
I want to upgrade to blade style fuses(put a nice clean box in) and replace my fuse box. I want to keep it simple. I will keep the same breakers & relays and may mold/create a special box for them(or maybe somehow include newer breakers and relays into the new box. I want to keep everything else where it is, just a box swap so to speak. Also, the terminals for constant power (and those ring terminal wires that connect to them) need to be kept. I also know that a starter relay and ampmeter need to be fed as well.
Do you all have any suggestions on where to start? I see all these Chinese boxes on eBay but I really wanted something solid. Maybe a later make of car? I am thinking about marine applications as well just case they get wet. My goal is for it to be as modern as possible and CLEAN from corrosion. If someone makes replacement fuseboxes or kits to rebuild a fuse box I am all ears as well. I am totally willing to rebuild mine
