2003 Stuck in park | Ford Thunderbird club group 1955-2005 T-Bird models
2003 Stuck in park
  • Thread starter Thread starter Blkbrd03
Blkbrd03
Blkbrd03
1
Any one know why my gear shift would be getting stuck in Park? I can eventually get it to move and the car drives fine, but the button you push in seems to get locked while in park. Would like to have a clue before calling Ford.
HELP!! 2002 Bird, 41,xxx miles. Starts fine but won't come out of park! No problem lights and don't have an ODB reader! There had been a problem with a flash flood and about an inch of water on the floors. Drained all water and ran a dehumidifier for two weeks until it came up dry after 48 hours. At least I need a hint on how to get it out of park so that I can move it before I try to replace the brake light switch....
Yet another senior moment! Any tricks to removing lower trim panel on dash to allow access to yhe brake light switch? I've removed the three scfrew/clips on the front edge and am afraid to breaking something by applying too much pressure! Panel is loose but seems to be held in the rear by something that I can't see.
After removing the driver seat to allow my 73 yr old and large body to see what I was doing I discovered that I had removed the dash pins rather than the proper lower trim panel pins. The switch is now out and waiting for Amazon delivery of he new switch. Fingers crossed ans many thanks for the asssistance with this issue. BTW I just downloaded a 10,000+ page 2002 service manual for only $5.00!! Seems to be OK! (onlymanuals.com)
Same issue here. I never noticed my break lights not working… I replaced my brake light switch. Brake lights work and I can now shift it from Park to Reverse.
Interesting note on the switch. When pulled it out of the box the plunger was longer than the old one. I had trouble trying to get it back in as the plunger was too “long”. I figured out that this plunger is adjustable. I had to push it in hard and it clicked into a shorter position. This solved the problem.
