2003 Crankcase Vent Tube Removal
wiggy
wiggy
Member
Nov 21, 2021
Want to remove crankcase vent tube. Have not encountered this type of clip before so before I break anything am seeking any advice about these clips Many thanks
Took mine off yesterday. See the little bumpy portion of the plastic ring that holds the hose to the chamber? Just squeeze the two opposing bumpy areas to together and tug on the hose. I had to actually squeeze it gently with a pair of channel locks due to not much finger strength. should just come off easily and snap back on.
Thanks for post. Did as you said worked great! I also needed tool assist,72 year old grip:confused:
