V
vbudwick
- Nov 4, 2021
- 1964
390fe mostly original except new MSD dist and coil conversion. Car was running fine for a while now. Then one day runs super rough like a big cam. Checked spark plugs to find that 2 cylinders, number 7 & 3 are not firing at all. Plugs wet with gas. 5 and 1 look like new, almost too lean. Rest look to be fine, to some degree. But 7 & 3 not firing at all. Checked firing order, good. Checked compression 120 all around, pretty good. Checked to see if plug had spark, yes and pretty good too. New wires. Swapped around plugs, lean for flooded and no difference just fouled 7 again. So spark yes, fuel yes, compression yes yet can’t get it to run right again. Need some suggestions / ideas. Car ran fine for some time
