- Jan 11, 2016
- 1963
Not sure if I can add my issue to OneAmongOthers post or start a new one so here goes.
While working on the convertible top I left the ignition on and went to lunch. Half an hour later the garage smelled of burning wire. Disconnected the battery and traced the smell to the pink resistance wire. The insulation was burned from the ignition switch to the the plug on the firewall. Luckily no fire.
This car has a Pertonix ignition. While doing research on this issue other 1963 Tbird owners members with Pertronix ignitions indicated that they had disconnected the resistance wire and taped it off.
The wiring diagram shows the engine side of the plug has 2 wires 1st a red-green to + side of the coil and 2nd a brown to the starter relay.
The present resistance wire is a total loss!
Will taping/disconnecting the resistance wire affect the cars operation/performance.
Thank you
Cam
Thank you
Cam
