- Jun 13, 2022
- 1959
I know this is a problem for many old cars and there are probably several posts and dozens of reasons why an engine will crank and crank before it eventually starts. But let me share my situation and perhaps we can narrow it down. I had a professionally rebuilt carburetor installed and prior to that it started okay. The crank was not long, but not quick either. Maybe 10-15 seconds. Now it cranks for over a minute and never starts. I'm sure I probably flooded it. After about 3 or 4 minutes I try it again and maybe after 15 or 20 seconds it tries to catch then eventually does start.
Because the carburetor was the only recent change, I suspect that is where the problem lies. I had it timed too, but I have spark at the plugs and coil so pretty sure the problem is fuel not ignition. I did notice the choke is not fully close when the car is cold and wondered should it be completely closed or open a 1/4 to 3/8 of in an inch like it is now? My manual doesn't really address that. Besides the choke is there any other adjustment on the carb that i should look at. Or could i be looking in the wrong place and its something else. Oh, and when i try to start the car after its been sitting for a week or more, i press the accelerator pedal twice then leave my foot off it. But after it cranks and cranks with no sign of catching i do pump it several times. Info just in case it might be driver error. Thanks.
