- Sep 20, 2020
- 1955
Just wondering if anyone has painted their engine bay without removing engine and trans?
How did it turn out?
Thanks guys
Thanks guys
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I did many years ago. It was touch & go. I did unbolt the hood release mechanism so I could get behind it. I forgot to tape off the fender junction blocks so they got painted. It's starting to peel in a few spots and you can see the original Coral Sand in a few spots as I didn't clean it well enough first.Just wondering if anyone has painted their engine bay without removing engine and trans?
Thanks guys
Thanks Ward 57. I also was thinking of taking mechanism off . So you did do the engine bay the factory color of the car? I have seen some that were done in black and I don't think they look as good as original color.I did many years ago. It was touch & go. I did unbolt the hood release mechanism so I could get behind it. I forgot to tape off the fender junction blocks so they got painted. It's starting to peel in a few spots and you can see the original Coral Sand in a few spots as I didn't clean it well enough first.
I had about a quart of paint leftover from the original repaint and used a DIY spray system with a glass container and a can of propellant to do it. Rattle cans are now available and if the color is not perfect not a problem for touch ups as I'm not going to eat off it.
Then it's the blackened intake manifold water pump and finally P/S fluid reservoir.
A friend of mine has a 1955 Thunderbird the same color as mine. In 2018, he painted the engine bay with the engine still in the car. Here are some before and after pictures.Just wondering if anyone has painted their engine bay without removing engine and trans?
Thanks guys
The factory color was Coral Sand but was painted a Navy blue when I got it including the trunk. The engine compartment had been left the original color. The whole car is now Colonial white so I did the engine compartment to match. The hood had been undercoated probably at the dealer so I left that black.Thanks Ward 57. I also was thinking of taking mechanism off . So you did do the engine bay the factory color of the car? I have seen some that were done in black and I don't think they look as good as original color.
Just my thoughts.
The hood mechanism is attached with studs on the firewall so it is a simple job to just undo the nuts on the brackets. Yah I did a lot of masking.Well Doug, that looks terrific. He did a spectacular job. I’m guessing lots of masking ? Is the hood mechanism attached with nuts on the other side of the firewall or will removing the bolts be a straight forward job with fixed nuts on the inner side?
It will be a few months before I can get to that. Now low 30's in the day and freezing at night here in the inland Pacific NW.Thanks for the pictures and information Doug. That is the exact same color as mine. Very nice job. Well done!!
I will get the masking tape out this week....
Don't just remove the hood mechanism, remove the master cylinder too. Not only is it easier to paint the firewall with the master cylinder removed, most likely the paint is peeled from spilled brake fluid or from a master cylinder that was leaking at some point in the past.Thanks for the pictures and information Doug. That is the exact same color as mine. Very nice job. Well done!!
Can you add some details to the master cylinder you are using? Is the rest of your power brake stock? This looks interestingI like using Eastwood Low VOC Pre Paint Prep, but be careful not to get it on any painted surfaces you won't be painting, it will strip the paint.
