This works on the 1994-
unscrew the black "covers"
take the seat back off the frame.
unzip/clip the bottom, pull it inside out over the headrest
pull the "c" clips off the mounts.
the headrest will slide off.
-OR-
Unscrew the caps where the headrest post go into the seat. Reach down the holes in the fabric/leather, where you will find a metal loop, the loop keep the headrest post in place via the notches in the post. Then use a pair of long nose pliers to pull the pin that holds the post in the mount. It will be on the side between the mount and the foam. After you pull both pins, the headrest will slide right out.
