J
JimB1957
- May 22, 2016
- 1966
Have a fully charged battery but when I pull the headlights on nothing happens and the horn does not work. The display in an after market radio illuminates. When I attempt a start the display fades away and nothing happens. Tested starter found bad, replaced starter and starter solenoid but still not start not even a turn over. Removed and cleaned connections at starter, solenoid, & ground wire to frame and engine block. Anyone got any suggestions? The engine does turn over by hand.
