- Jul 31, 2018
- 1967
A new way for a lot of you to do your brake bleeding from now on.
I know a lot of you are still doing the old fashioned way of having someone pump up the brakes while you bleed the wheel cylinders & keep repeating this process to no avail sometimes.
Get yourself a clear pop bottle or jar so you can see through it.
Get yourself 12-16 piece of rubber hose that fits snugly over the wheel cylinder bleeder nipple.
You might have to make it longer if needed
Loosen up the wheel cylinder bleeder but slightly unloosening & tightening it until it's loose. Don't just crank on it and break it.
Make sure the master cylinder if kept full during this process.
Fill the bottle or jar up half way with brake fluid.
Put the rubber hose on wheel cylinder bleeder nipple & the other end down into the brake fluid of bottle or jar.
Unloosen the wheel cylinder bleeder
Have some one pump up the brake pedal slowly & smoothly until all the air bubbles are gone & only brake fluid is coming through the line.
Tighten the Wheel cylinder bleeder
Do this to all 4 brake wheel cylinders & you will have no air in your brake system
THIS IS THE CORRECT WAY TO BLEED BRAKES WITHOUT USING ONE OF THOSE BRAKE BLEEDING MACHINES OR KITS THAT'S NEVER WORKED FOR ME
Try it next time & give me your feedback
