Hi,
You did not say anything about adjusting the idle air adjusting screws at the base of the
carburetor. There are 2 of these screws, one for each primary venturi at the front of the
carb. Screw both of these screws LIGHTLY in until each one is closed. Then back each one out 1 1/2 to 2 turns. then start the car. Use the idle speed adjusting screw to bring the idle down to maybe 800 rpm or whatever speed you can get to before it stalls. Now, using either a vacuum gage or tachometer, adjust first one of the air adjusting screws in or out to maximize the vacuum or rpm and then the other. It is now a matter of adjusting the rich/lean idle adjusting screws and the idle screw to get the engine to run smoothly at a reasonable rpm. If you
search the internet you will be able to find a more detailed
Holley adjusting procedure.
Good Luck,
Use these simple tips to adjust the idle mixture screws on
Holley carburetors to eliminate hesitation, rough idle, backfire, stalling and more...
Holley carburetors have idle mixture screws that control the air/fuel ratio at idle. Improperly set idle mixture screws are often the reason for
carburetor symptoms such as hesitation, rough idle, backfire, stalling, hard starting, engine surge, and more. Fortunately, it's easy to adjust the idle mixture with a simple screwdriver and a quality
vacuum gauge. The first step is to ensure that there are no
vacuum leaks, so check all the hoses leading to and from the
carburetor and
intake manifold for cracks.
There are two idle mixture screws on the primary metering block of the
carburetor. You will need to adjust both idle mixture screws for proper operation.
Connect a
vacuum gauge to a manifold vacuum port and follow these procedures to obtain the highest amount of vacuum reading possible.
Step 1) With the engine off, start by turning one of the idle mixture screws located on the primary metering block, all the way closed (clockwise), until it lightly seats. The primary metering block is the one closest to the front of the engine.
Step 2) Then turn the idle mixture screws counter clockwise one and one half turn. Do the same for both idle mixture screws.
Step 3) Start the engine. If it has a difficult time idling adjust the curb idle speed screw (clockwise) so that the engine won't shut off.
Step 4) Let the engine warm up and make sure that the
carburetor's choke is off.
Step 5) On a vehicle with an automatic transmission, have someone sit in the car and set the parking brake. Then have them put the transmission in drive while they are depressing the brake pedal. Do not touch or rev the accelerator pedal. On a manual transmission car, the idle speed adjustment can be set with the transmission shifted into neutral and the parking brake is set.
Step 6) Adjust each idle mixture screw by turning them clockwise and counter clockwise, until the
vacuum gauge reads the highest possible vacuum reading. All the idle mixture screws should be adjusted the same amount.
Step 7) Once the highest vacuum reading is achieved, you can adjust the curb idle speed screw so that the engine idles at the proper engine RPM.
Once properly adjusted, you'll notice better fuel economy, more power and quicker throttle response.
!955 Thunderbird Blue
