2002 Lower dash panel is loose
P
PPA
Jan 23, 2020
2002 Bird Lower dash trim, a few inches from driver left knee is popping loose. Need new or a fix?
thanks
If you have the part that has broken off, you can mix superglue and baking SODA (not powder) to make a strong repair that will not break in the same place again. Go on YouTube and check out the videos. If the piece is missing, you can build up the repair slowly, or bond some plastic from another source to mimic the original piece. Let us know how it works for you.
