D
dwb73
- Jul 11, 2021
- 2002
My ABS and traction control lights are on. My mechanic says it needs a wheel sensor and an ABS pump. The wheel sensor is easy enough. We can't find an ABS pump. Ford says they are discontinued, and I understand that the 2002 model is different from 2003-2005. Someone said Tbird, Lincoln LS, and maybe Jaguars shared some of the same parts in 2002 but I haven't found anything so far that looks like a solution.
Found a couple of used parts online but I'd rather go reman if I can't get OEM or aftermarket.
02 FORD THUNDERBIRD ABS ANTI LOCK BRAKE PUMP MODULE MODULATOR 1W432C219BB.
Can it be rebuilt? Any recommendations on a remanufacturer for this particular part?
