1997 T-Bird Leaking
K
Aug 12, 2004
My 1997 T-bird is leaking and getting the headliner wet right above the top of the backseat on the drivers side. Has anyone had this problem and if so where is the water coming in at?????? Thanks
Isn't there a seam on the roof where the roof panel and top of the body side meet? Seems like there is a rubber or plastic filler piece at the seam. Do you have a moon roof where water could be entering and running to the back?
Leak
Yes I was told on another board to gently take of the black molding around the back glass. There is a channel there. To clean it out and put a sealant on then put the molding back on. Gonna try this. Thanks for the quick reply :confused:
