O
Oldfordcrap
- Sep 2, 2016
- 1969
Hi my first post, I have a 1969 2dr landau 429 all stock pass Side window was having problems going up. Then the window motor died so I took the door apart removed the glass and regulator got to the motor and replaced it.now when I removed the regulator the big spring fell out,I simply put it back but there is no tension on it at all. I assume there should be a fair amount of tension in the down position to take some of the load of raising the window. Do I have to put tang in with a turn on the spring to load it up? Should it be loose? Even with the new motor the glass is labouring when raised . Any help would be appreciated
Thanks
Ralph
Thanks
Ralph
