1965 Leans to left rear
delay41
Sep 22, 2022
My 65 leans to the left rear. New springs installed last summer. Ideas?
New springs on the front or back or both? Does your car have AC?? If it has AC the left front spring is stronger than the right. Where did you get your springs?
Is this something new or has the car always done this?
New springs in rear. Lean on left rear.
Place a floor jack under the Center of the front crossmember and lift the car until the front tires are just off the ground. If the rear now sits level then the issue is not the rear springs.
