1963 turn signal fuse blows when car is started
J
Apr 12, 2023
The fuse for my directional signals blows every time I start the car. Thoughts...........
Please follow the posting prompts in the future. How is anyone supposed to know what your post is about when you titled it "1963"? Subject has been revised.
generally if you blow a non related fuse it's a ground issue, check all your grounds
After replacing the fuse does it stay intact until the next time you start it with the ignition on?
might be a short in the steering colum wires. or in the wirte loom it self out by the fenders. try taking the bulbs out / all of the turn signals ones, then go from there replaceing them one at a time. then u can trace down the bad grounded out wire.. proply something real simple that is doing this,
