Does anyone know how to replace the swinging bird head to the trunk emblem. I have no idea how to attach the spring or the bird head to my 63 T bird. Thanks
This site contains affiliate links for which I may
be compensated. As an eBay Partner, and Amazon Associate I may be compensated if you make a
purchase at no cost to you.
When I bought the part from a thunderbird retailer all that was sent to me was the bird head and a small spring but no push on clip. Maybe I'll have to take it off and see. Thank you for the feedback
I just replaced Ming you have to remove the 2 spread clips and 1 large nut inside the trunk that holds the emblem on them you will have acces to the back of emblem you will see a slot and the spring winds to have tension and the cross piece go into the slot then reassemble on trunk
