- Feb 10, 2023
- 1961
After installing the second new master cylinder, cleaning and lubricating adjusters , checking wheel cylinders, bleeding master and all 4 wheels and installing a new brake light switch I finally have a good pedal. Now I find that the brake light switch is leaking allowing the pedal to get lower and lower. I’ve tried wrapping it with a couple of turns of Teflon tape but that hasn’t stopped the leak.
I hesitate to put gasket sealer on the threads but I’m not sure what other solution there might be.
Has anyone had this same problem and how did you solve it?
