1957 transmission fluid type
CharlieWilmot
CharlieWilmot
May 9, 2024
Hello everyone, my name is Charlie in San Diego California. Have a transmission fluid question. I recall always using type F transmission fluid, I was watching some videos on YouTube saying that’s not the correct fluid. What say you?
Also, I seem to remember the car should be level. Idling in neutral when checking fluid level, is that correct?
Thanks!
I had read about 2 years ago. It is Type A and not available anymore and that Dexron lll is the closest to the Type A and is preferred…there must be a post here on the forum about it
The Thunderbird Restoration and Details Manual recommends Dexron. Type F will give firmer shifts but shorter lifespan, unless you change the fluid more frequently.
Agreed ! Reason is these engines get HOT quicker......
Thanks!
Yes. Car level, idling and warmed up to operating temperature, and either neutral or park for Ford products. Some others, like Mopars I believe, were neutral only.
