- Dec 8, 2022
- 1957
I am trying to figure out what the problem could be before I crawl under the dash. I checked for continuity on the hydraulic brake light switch and have continuity when I step on the brakes. The turn signals work properly. All the light bulbs work. I believe the turn signal and brake light is the same filamet. I checked for voltage on each of the two green wires that attach to the brake light switch and there in no voltage on either one. The cigar lighter works as does the radio. It is hard for me to get down and look behind the dash so I woul like to have an idea of wht color wires to check without looking at everything. Any ideas would be greatly appreciated.
Thank you, Dukie
Thank you, Dukie
