- Apr 18, 2022
- 1957
Has anyone put a 351w with a overdrive Trans ina57 third ? If so could advise of what modification you had to make. And how you liked the performance?
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Yes . Rack an pinion new springs shocks swaybar all newResto-mod? Are you planning on suspension upgrades? Sounds like a big project.
Hope you get as much enjoyment out of it to what you can afford. As Zero stated, a BIG job.Yes rackand pinion new spring shocks swaybar all new
Yes, no P/S No P/B but it's still drivable just a little more raw, But it keeps you in shape and YES they are fun to drive. I keep my very early '57 as close to original as possible. Just Found an original jack to finish up my trunk. The matting is beyond getting perfectly clean but it's a driver almost 100% to original.Frankly owning an original classic is my bag. I’ve had others like my highly modified chopped ’37 Ford Tudor Humpback, but to tell the truth I love driving and working on this classic original. I get great pleasure in trying to keep her in original stock condition with as few modifications as possible. Wish I had PS & PB but she’s fun even if I have pump iron to stop, steer and park her ?
Glad you have enjoyed it. I am leaving tomorrow to Alaska and will be gone to the end of month.I would love to talk to you about the engine swap. I am new to the forum and are no familiar with rules on here.I built a new crossmember for the engine mounts. Your biggest clearance issue is on top especially toward the front. use a low manifold mine is edlebrock rpm w/750 carb. too tight 15 plus years lots of miles &smiles aod trans w/373 rear gears It is a hoot to drive 351 w w/ stroker 393 ci DO IT
Your trans tail shaft passes through the x frame that will lock in your height I raised the body 5/16" to clear my oversize dui dist and carb on med rise manf. If you use small dist and low rise manf. you should be ok w/o lifting body. Happy to helpGlad you have enjoyed it. I am leaving tomorrow to Alaska and will be gone to the end of month.I would love to talk to you about the engine swap. I am new to the forum and are no familiar with rules on here.
What did you do about power brake boosterYour trans tail shaft passes through the x frame that will lock in your height I raised the body 5/16" to clear my oversize dui dist and carb on med rise manf. If you use small dist and low rise manf. you should be ok w/o lifting body. Happy to help
