1956 missing frame vin
ron56
ron56
Mar 17, 2020
Has anyone run across a case where the vin number on the passenger side frame rail is missing, I can clearly see from pictures where the vin should be but I don't see any sign. I don't think it has been ground off because I see the welding splatter all around the frame seam. The information on the data plate matches the original Ford sales invoice. When we stripped the car for paint nothing said the car had been in a wreck.
There are three places on the frame where the VIN number is stamped. Unfortunately, to view the other two locations the body has to be removed.
The stamping is sometimes light. take some sandpaper and sand down the area where the VIN should be and you will be able to read it. I suppose it is possible that it left the factory without the number stamped, but I would think it highly unlikely.
Take white distilled vinegar and paint the area of the vin with it let set for a half hour then reapply the vinegar do this 4 or five times then let set a few hours if it’s there you will see it. When done rinse the neutralize the the area and apply paint. In my state they verify the frame # to the ID tag
Hope this helps. Numbers on fender side of weld.
I feel a little silly. After finding a solvent for the POR 15 that I painted on the frame about 4 years ago I found the vin numbers. I used a paint remover from Jasco, left it on for about 1/2 hour and the paint came off easy. I think I'll take a picture of the vin number before replying the POR.
