- Nov 7, 2021
- 1956
What color should the cork band on front of air cleaner base be, argent silver or cork?
Thank you,
Chuck
Thank you,
Chuck
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Argent is Ford's name for low gloss aluminum color paint. The air cleaner base along with the cork seal were painted argent. If the air cleaner lid was non chrome, it was also painted argent.What color should the cork band on front of air cleaner base be, argent silver or cork?
Thank you,
Chuck
Really? Everything I've seen is natural cork. I guess there are none of the original owners around who could verify. I'm then going to assume the cork was installed before painting. But the marketing team would deny it as the paint would crack and peal within months. Plus the natural cork would help draw your attention to the chrome air cleaner cover.I disagree - the cork is supposed to be argent. Authenticity judging specs says argent
Mine is "natural" cork. Not sure if original though.What color should the cork band on front of air cleaner base be, argent silver or cork?
Thank you,
Chuck
When I repainted the lower part of the air cleaner, I painted everything, including the cork, according to the guidelines. Did this 10 years ago. No peeling or other problems with the paint on the cork.Really? Everything I've seen is natural cork. I guess there are none of the original owners around who could verify. I'm then going to assume the cork was installed before painting. But the marketing team would deny it as the paint would crack and peal within months. Plus the natural cork would help draw your attention to the chrome air cleaner cover.
From a marketing standpoint more colors meant looking more like art. Red block, fancy valve covers, Black relays & associated electrical parts.
I just read the above post. Fascinating
I painted my cleaner base with rostellum aluminum. Looks great.
one of my projects this spring is to spruce up the engine compartment and painting the P/S pump reservoir. what to use to clean it first ? Mineral spirits or alcohol, I have both.
BraKleen and mineral spirits may take off the old paint . Not sure about denatured alcohol. For items I don't want to remove the old paint I use a product like Prep Sol.This has been interesting. I used the Rustoleum aluminum on my cleaner base but didn't paint the cork as I didn't know they came that way. It looks almost like argent and it's mostly hidden so no problem.
I want to paint my P/S pump reservoir but I'll use the argent. What is the best solvent to clean it first? I have denatured alcohol and mineral spirits and a couple of cans of BraKleen also.. I'm going to do it on the car as I touch up the rest under the hood.
I don't want to remove the old paint just get it clean from the P/S fluid so the paint will stick.BraKleen and mineral spirits may take off the old paint . Not sure about denatured alcohol. For items I don't want to remove the old paint I use a product like Prep Sol.
Another cleaner I like is Super Clean (purple cleaner). Works very good on grease and oil. If I'm going to paint it afterward, I use soap and water just to make sure the Super Clean is not a problem with paint.I don't want to remove the old paint just get it clean from the P/S fluid so the paint will stick.
Mineral spirits will not take off the paint if it is well adhered. Alcohol is a possibility, and has very mild solvent properties. I use it for detail cleaning, and it won't hurt the paint. Brake cleaner is definitely a "hot" solvent, and will remove the paint, or at least soften it, as will Acetone. Were it me, I would definitely strip the tank before painting it. No sense in taking every thing apart, then doing a half way job!I don't want to remove the old paint just get it clean from the P/S fluid so the paint will stick.
I don't plan on taking it apart. If 'If it ain't broke don't fix it is the way I go. It's a driver and everything works. Just want to dress it up for local shows. The cork on the air cleaner I will leave natural and I like the contrast. Just stuffed it in with no staples and no issues.Mineral spirits will not take off the paint if it is well adhered. Alcohol is a possibility, and has very mild solvent properties. I use it for detail cleaning, and it won't hurt the paint. Brake cleaner is definitely a "hot" solvent, and will remove the paint, or at least soften it, as will Acetone. Were it me, I would definitely strip the tank before painting it. No sense in taking every thing apart, then doing a half way job!
Really indeed!Really? Everything I've seen is natural cork. I guess there are none of the original owners around who could verify. I'm then going to assume the cork was installed before painting. But the marketing team would deny it as the paint would crack and peal within months. Plus the natural cork would help draw your attention to the chrome air cleaner cover.
Ward,I don't plan on taking it apart. If 'If it ain't broke don't fix it is the way I go. It's a driver and everything works. Just want to dress it up for local shows. The cork on the air cleaner I will leave natural and I like the contrast. Just stuffed it in with no staples and no issues.
