- Dec 29, 2014
- 1955
I have removed the clock from my 1955 Thunderbird and I want to see if I can repair it. Over the past 4 years the clock has been operating without any problems, but recently it seems to stop. After I set the time it will operate normally once again. The clock is a 6 volt positive ground manufactured by Motochron. Before I attempt to disassemble the clock, and so I don’t damage anything I have a few questions.
How do you remove the set knob from the set stem so I can remove the clock lens?
How do you remove the clock assembly from the metal case?
Has anyone successfully repaired one of these clocks or is a quartz conversion my only option?
