M
- Apr 19, 2018
- 2012
Hoe do you change odometer scale to metric?
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I think you just push the button by the trip odometer and hold it in till it changes.Hoe do you change odometer scale to metric?
The odometer does not change, the same platform as was used in the Thunderbird was also used in the Lincoln LS and Jag S type and those systems do allow you to change the odometer to miles from Kilometers. You have to have the dealership change out the module, they can do a sworn affidavit stating the mileage was changed too.Hoe do you change odometer scale to metric?
I wrote the wrong name I Think. I should have wrote Speedometer scale to metric.Aw .. you no doubt are right on that
There is no easy way, you can check with the Ford dealer and see if they can flash it. Here is an old thread- https://forums.fordthunderbirdforum.com/threads/miles-to-kilometers.2991/I wrote the wrong name I Think. I should have wrote Speedometer scale to metric.
