B
- May 31, 2009
- 2005
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Mine is nearly always there.Is the static all the time, or does it vary with engine speed.
Depending on the above, could be several things, or the nature of
AM radio, ampilitude modulation.
From my experience as an aviation mechanic “static” is caused by diminished ability of the equipment which is less likely with today’s modern electronics or more likely poor antenna connections or antenna, either the core or the ground. Clean those connections. See if it helps. Where are you? For example, My 2002 has lived it’s life in a dry climate and garaged 68K miles and the sound system sounds like new.How do I stop static on stock AM radio on 2005 TBird
I found one report that said the radio antenna is just forward of the right door behind the fender and maybe you can see it looking forward with the door open? My car is parked so I cannot check that but will check tomorrow. Any corrosion on any connection, maybe even the mount to the body could cause static.I am in CT and it had static when I bought it at 44k miles in PA and there has not been a change and I am at 97k now.. Where do I find the connections besides the antenna plug going into the back of the radio? Is there a test I can do at that plug? Maybe pugging in an old car antenna (if I can find one) would isolate the issue.
That’s good to know!The radio antenna is bonded to the center of the windshield, Starts behind the rear view mirror at the top, and runs down
almost to the bottom of the windshield. There has to be some sort of connection at the top center of the windshield.
Might have a loose ground, or worn out electronics inside the radio.
I just tested the radio with the engine off and it fine (as AM can be). When the engine is running the noise varies from station to station but is not affected by engine RPMs so I suspect the Antenna or it's connection is the issue. The next warm day before I put the hardtop back on I will do some testing. I have lived with it since 2009 so it may wait till spring.Have you tried putting a Bounce dryer sheet in the CD slot?
