B
Bdad3
- Jun 9, 2021
- 2002
I have the equipment and thought I'd at least try to trace the problem. I've heard that a bad transistor has been found to be the issue sometimes.I would not try and repair yourself unless you have some very good soldering equipment, and good de-soldering equipment. FEMs are hard to find and
if you damage them in any way the few repair facilities there are will not touch them.
I used to work on Motorola hand held radios and have the soldering equipment to work on them, and even with that I decided not to touch the FEM, I
sent it off for repair which was a wise decision.
Some of the transistors are very hard to find, which is usually what is wrong, and many of the ICs are 40 leg ICs, and very difficult to unsolder the IC
legs, they are very close together.
