- Aug 28, 2019
- 2005
I had purchased a FIXD device and ran it the first day that I got ot and all was fine. I have installed a new radio and so I had disconnected the battery while doing so. I then got NGK BKR5EGP plugs from a posting on this site with amazon. After painstakingly removing the spark plug covers (PITA driver side), I then began the process of removing the COP, then the plug, inserting the new plug, putting the coil back on. Each time I put dialectric grease on the COP end smearing it around the inside so the COP hole was covered. I saw this in the service manual I bought (also as a link from this site). All plugs were torqued and I checked the gap which was about .040 and I have seen here and in the manual the the gap is .039 to .043. I started the car and it started fine but I thought that it might be running a little rough although not really that noticeable. I hooked up the FIXD and now I get two error codes p1000 on board diagnostics not complete and p0354 ignition coil d primary/secondary. There is no light on in the dash. FIXD diagnostic says that if there is no light present on the dash that this may be due to perfectly normal fluctuations of the car's computer. I'm wondering if it could just be maybe too much dielectric grease. After turning the car off, I wend back to make sure all coils were seated properly and pushing down on one, it cracked at the COP bolt. I made sure it was pushed down and then restarted the car. I now felt that it was running smooth but FIXD still reported the errors. I have not taken it for a test drive as I don't want the COP to pop out while driving and am purchasing a new COP. Any ideas on what may be causing the error codes?
