mustangshar
- Apr 8, 2018
- 2004
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I’m sorry, thank you so muchPut the model year in the subject. Added for you.
Those all seem logical but they don’t say how to get it off.Is it the gas cap or fuel door?
From https://www.yourmechanic.com/estimates/ford/thunderbird/gas-cap-won-t-come-off-inspection
Common reasons for this to happen:
There are three common reasons why your gas cap might get stuck on:
- Vacuum sealed: Under certain conditions, your gas tank can create a vacuum-like seal around the gas cap, which seals the cap tight. This vacuum situation occurs when the pressure inside the gas tank changes, which can happen due to extreme changes in weather or altitude, among other things. This high pressure situation creates a vacuum seal that makes it nearly impossible to unscrew your gas cap.
- Poorly threaded cap: Be it out of haste or simply not noticing, sometimes people screw on their gas caps incorrectly. If the thread does not match up, you can sometimes force the cap on, just like you can force a glass jar lid on even when you’re not screwing it on correctly. If this happens with your gas cap, it can be extremely difficult to get off.
- Debris in the threading: If dirt, leaves, or any other form of debris contaminates the gas cap and gas tank threading, the cap can easily get stuck. This debris can get trapped in the threading, creating extra pressure and friction, making the cap resist that much more when you try to unscrew it.
I have to agree with you 100%. My handle on this forum is "HATE THIS FORD" some members comment to me why I don't sell it. (I offered it for 7K, but no takers) The reason for my handle, I never had a car with everything on it has problems. Engine, transmission, suspension, fuel, windows, chrome pealing, heater valve, A/C and ECU's. Thousands spent, more problems ahead!
