T
The Flash
- Aug 9, 2005
- 2003
To change the Trans. Oil and filter on my 2003 I had to remove the bottom frame X member. Then holding the trans. up remove the trans. support. To drain the oil pan remove the big plug with the oil level check screw place. Two small bolts hold the filter in place.
When filling the trans. with oil I used this pressurized sprayer. See picture.
I looked everywhere on the internet to see if Ford gave us a convenient way to fill the oil and found NONE.
BUT I did find on the back of the trans. on the right side by the output shaft, there is a FILL PLUG. See picture.
